TheYak Posted December 4, 2006 Share Posted December 4, 2006 Hey guys, i'm having a problem with my heater. The only thing place that it will blow heat from is the defogger option. No matter what the control setting, it blows by the windshield. It just recently starting doing this, can anyone point me in the right direction?? Thanks guys! Link to comment Share on other sites More sharing options...
Eagle Posted December 4, 2006 Share Posted December 4, 2006 Yep -- you have a vacuum leak. The heater controls use vacuum to control the flappers, and the default position when they lose vacuum is the defrost position. On an '86 I don't think you have the round or oblong vacuum ball or "blimp" that the later models have, located behind the front bumper on the right side. I believe yours should have the tin can vacuum reservoirs -- look under the hood, on the right side of the vehicle, probably mounted on the inner wheel housing. Follow all the vacuum tubing and look for cracks and/or splits. Link to comment Share on other sites More sharing options...
TheYak Posted December 5, 2006 Author Share Posted December 5, 2006 Thanks, i'll check it out :cheers: Link to comment Share on other sites More sharing options...
sinnaevd Posted December 5, 2006 Share Posted December 5, 2006 i think 89 was the change over between the ellipsoid and the sphere, my old 89 had the ellipsoid, my new to me 89 has the sphere Link to comment Share on other sites More sharing options...
Eagle Posted December 5, 2006 Share Posted December 5, 2006 i think 89 was the change over between the ellipsoid and the sphere, my old 89 had the ellipsoid, my new to me 89 has the sphere No, my '88 has the sphere. The sphere has only one chamber, the ovoid has two chambers. It was used with some extra options, usually cruise control (which uses engine vacuum to regulate the speed). Link to comment Share on other sites More sharing options...
mike Posted December 5, 2006 Share Posted December 5, 2006 i have an 86 with the 2.5L and it has the oblong one. i'm sure it came that way from the factory as the original owner was an older guy and never did any messing with the truck except normal maintaince. Link to comment Share on other sites More sharing options...
