Re-locating shock mounts
The D-35 finally started making noises.. time to swap in the 8.25 I have already. How do you guys know where exactly to mount the shock perches? Is there a specific way to do it, or should I just measure? I can obviously figure out the distance from the drum to the perch but how do I figure vertical ways where it should go?
Thats what I am talking about... Is there a page that explains this in a little better detail? My D35 is howling at me, prolly since I have been plowing snow with the truck. :fs1: I am still running the axle on top on the leaves but with 1" lift shackles.
Correct; you will simply need to weld on new spring perches (photo below). If your using a XJ 8.25" the perches from the factory will be on top; thus if you keep is SUA (spring under axle) you won't even need to remove them, simply just weld on new perches in the correct location for the MJ leafs.
The shock mounts can be re-used with your factory mounting plates. Just remember to purchase new u-bolts as well as you should never re-use the old bolts.
Thanks! Where can I buy a new set?
Will these be the ones? I figure if I get a set you pictured it would drop the rear a half inch.
http://www.quadratec.com/products/56311_0001.htm
You will need one's that are 2.5" wide; the one's you linked are only 2" wide.
You'll want something like this if your worried about height of the perch; http://motionoffroad.com/catalog/index. ... ts_id=2256
