fiatslug87 Posted January 16, 2011 Share Posted January 16, 2011 I've searched but I'm still stumped. '89 MJ 1- Left front parking light will not illuminate (right is good) 2- Works when signaling/flashers, although dim (only one filament is on) 3- Left turn indicator dash light is on when parking/headlights are on 4- Bulb is OK (switched in one that worked) 5- Swapped in two other harnesses (I KNOW one worked when pulled 3 months ago) still the same 6- According to the wiring diagram (see below) the left uses pin 3, the right pin 8, and both share pins 4 & 5 7- Voltages were the same at pins 3 & 8 (engine side) What am I missing? All three harnesses can't have the same bad socket or short, can they? Link to comment Share on other sites More sharing options...
alleydog Posted January 16, 2011 Share Posted January 16, 2011 I'm thinking you don't have a good ground at the left park light, so it feeds back through the turn signal filament and puts the indicator on. you can verify that by using a test light clipped to battery negative, and touch the pointed tip to the base of the left turn bulb. If it lights with the park lights on, you don't have a good ground. Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 16, 2011 Author Share Posted January 16, 2011 But wouldn't that mean all three harnesses have the same problem? I'll try it tomorrow. Link to comment Share on other sites More sharing options...
alleydog Posted January 16, 2011 Share Posted January 16, 2011 yes, it does. Its weird! Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 17, 2011 Author Share Posted January 17, 2011 I ended up replacing the socket with a functional one from a spare harnesses (I couldn't find a replacement at the local parts stores :grrrr: ), now it works properly. I guess all three harnesses had bad left sockets, what are the odds :hmm: ? Time to hit the Lottery??? Link to comment Share on other sites More sharing options...
alleydog Posted January 17, 2011 Share Posted January 17, 2011 good to hear you got it fixxed. That was an odd deal to have all three bad! Link to comment Share on other sites More sharing options...
