ECU question
You can burn out the transistors that supply the neg signal to the injectors and the engine will still run,it just won't run on that cyl.
Or could have a corroded pin or burned pathway on the board,depending which one the engine could still run.
The truck is still running real bad. I have replaced:
Fuel pump
Gas tank
Fuel filter
MAP sensor
Throttle position sensor
Idle speed motor
Knock sensor
Spark plugs, wires, distributor cap and rotor
Bypassed ballast resistor (it is bad, need another one).
I have checked the vacuum system, do not see any leaks, if I bypass the MAP sensor it will run a little better, which is not saying much. If I reconnect it, it will hardly run. I put a new MAP sensor in and it did not make a difference. I am running out of ideas. Thanks.
