freakjeep93 Posted January 4, 2011 Share Posted January 4, 2011 i know this isnt a car forum but i need some help.yesterday me and dad took my dash apart to install a sub in my 1998 Hyundai elantra, and today i have no heat. my question is. is there anything in the back of the dash that controls if you get heat or not. i have played with the control on the heater box that the heat knob goes to and i still don't get heat even when thats turned to the maximum to each direction and still no heat. Link to comment Share on other sites More sharing options...
Automan2164 Posted January 4, 2011 Share Posted January 4, 2011 I'm no Hyundai tech, but I would start by pulling thing back apart and checking all the things you might have touched. Also check any fuses to see if you got a couple wires crossed and popped one. Rob L. Link to comment Share on other sites More sharing options...
freakjeep93 Posted January 4, 2011 Author Share Posted January 4, 2011 okay that will be first on the todo list for tomorrow. Link to comment Share on other sites More sharing options...
valis Posted January 4, 2011 Share Posted January 4, 2011 Might not need to pull the whole dash back out, but maybe enough trim pieces to gain you access to some of the wiring so that you can see if there is an obvious problem - like a disconnected wire. You say you have no heat, but is the blower motor running? Are you getting anything at ALL? Cold air? Or nothing? If the blower motor isn't running at all, sounds like a wiring/fuse issue. If the blower motor is running, but you don't have hot air, sounds more like a mechanical linkage issue. I'm assuming that because this is a Hyundai there is either a mechanical linkage or a vacuum operated switch that regulates the airflow around the heater core. Link to comment Share on other sites More sharing options...
freakjeep93 Posted January 4, 2011 Author Share Posted January 4, 2011 the blower is running. and I'm getting cold air. the linkage from the knob to the heater box is hooked up. and i can turn the heat control easily.and the control is turning the linkage at the heater box. i ahve crawled in there and actually mover the linkage by hand aswel and still no heat. Link to comment Share on other sites More sharing options...
valis Posted January 4, 2011 Share Posted January 4, 2011 the blower is running. and I'm getting cold air. the linkage from the knob to the heater box is hooked up. and i can turn the heat control easily.and the control is turning the linkage at the heater box. i ahve crawled in there and actually mover the linkage by hand aswel and still no heat. Any valves on the the heater core lines under the hood that could be cutting off flow all flow to the heater core? When the engine is running and is up to operating temperature turn your heat on full blast and feel the heater core lines under the hood. Feel them up by where they go into the firewall. One of them should be hot. The other should be a little cooler. Link to comment Share on other sites More sharing options...
jpdocdave Posted January 5, 2011 Share Posted January 5, 2011 wow. Link to comment Share on other sites More sharing options...
jpdocdave Posted January 5, 2011 Share Posted January 5, 2011 i know this isnt a car forum but i need some help.yesterday me and dad took my dash apart to install a sub in my 1998 Hyundai elantra, and today i have no heat. my question is. is there anything in the back of the dash that controls if you get heat or not. Um, everything that controls your heat or a/c is there.........................you screwed it up. I just have to ask..............why? Link to comment Share on other sites More sharing options...
freakjeep93 Posted January 5, 2011 Author Share Posted January 5, 2011 i know this isnt a car forum but i need some help.yesterday me and dad took my dash apart to install a sub in my 1998 Hyundai elantra, and today i have no heat. my question is. is there anything in the back of the dash that controls if you get heat or not. Um, everything that controls your heat or a/c is there.........................you screwed it up. I just have to ask..............why? i needed to get at wires to install a subwoffer. everything i unplugged i plugged back in. my linkage is operating the heater valve, and the ac and HVAC controls are lighting up and operating. what i meant by my question is if there is a electronic switch that control if you get hot coolant going through you heater core or not. Link to comment Share on other sites More sharing options...
tbrand Posted January 5, 2011 Share Posted January 5, 2011 i know this isnt a car forum but i need some help.yesterday me and dad took my dash apart to install a sub in my 1998 Hyundai elantra, and today i have no heat. my question is. is there anything in the back of the dash that controls if you get heat or not. i have played with the control on the heater box that the heat knob goes to and i still don't get heat even when thats turned to the maximum to each direction and still no heat. I'd poke fun for putting a sub in a Hyundai, but I rolled with a 10" sub and a huge amp in my '95 Caravan in college. Link to comment Share on other sites More sharing options...
valis Posted January 5, 2011 Share Posted January 5, 2011 i needed to get at wires to install a subwoffer. everything i unplugged i plugged back in. my linkage is operating the heater valve, and the ac and HVAC controls are lighting up and operating. what i meant by my question is if there is a electronic switch that control if you get hot coolant going through you heater core or not. On a '98 Hyundai Elantra? I doubt it. I'll see if I can dig anything up on the HVAC system for that vehicle. Link to comment Share on other sites More sharing options...
freakjeep93 Posted January 5, 2011 Author Share Posted January 5, 2011 okay thanks Link to comment Share on other sites More sharing options...
valis Posted January 5, 2011 Share Posted January 5, 2011 I dug this image up that is supposed to be a '98 Elantra heater box assembly: My main concern would be that the vacuum connector displayed on the above picture is either disconnected or not properly connected or there is some sort of vacuum leak on it. Link to comment Share on other sites More sharing options...
freakjeep93 Posted January 5, 2011 Author Share Posted January 5, 2011 okay so i guess my plan of attack is to make sure everything is hooked up in the right places and/or hooked up. Link to comment Share on other sites More sharing options...
valis Posted January 5, 2011 Share Posted January 5, 2011 okay so i guess my plan of attack is to make sure everything is hooked up in the right places and/or hooked up. That'd be a start. Link to comment Share on other sites More sharing options...
freakjeep93 Posted January 5, 2011 Author Share Posted January 5, 2011 thanks for the help guys. i got it figured out, i took the dash back apart and everything was good so i took a close look at the linkage for the heater core. thit ends up tat the rod that connects the linkage to the door inside the heater corehad come off the linkage. hooked it back up and ive got heat back!! Link to comment Share on other sites More sharing options...
valis Posted January 5, 2011 Share Posted January 5, 2011 hooked it back up and ive got heat back!! And bass bumpin' tunes. Big pimpin' in the Hyundai :D Link to comment Share on other sites More sharing options...
