webbjeepxj Posted January 3, 2011 Posted January 3, 2011 I have been viewing all sorts of threads on clutch bleeding, I need to clarify some things. I went out to Autozone and bought a master, slave, and hard line. Totalling $75, figured do it all once and done. What is the correct procedure for the 86 with the external slave? Is it possible to pre bleed the system then install? I read something about depressing the slave while bleeding?
jimmy21669 Posted January 3, 2011 Posted January 3, 2011 Hold the slave with the push rod end facing the floor. Ensure that the slave is the lowest part of the system. With the cap off of the master, depress and release the slave cylinder. DO this until no more air bubbles up out of the master. DO NOT do this too quick, and DO NOT allow the slave plunger to fully cycle. This will ensure the seals do not blow. One complete, install the slave to the bellhousing, put the cap on the master. Go. Hope this helps. Jim
