I am in need of a front and a rear driveshaft for the refuge.
I have a 4.0L/ax-15/231 shortbed with a D30/D44 combo. I am in need of these soon and if I can't find factory ones will have to order new ones. Would rather save some cash and buy older factory ones.
I had rear one custom made for my 4.0L/ax-15/231 shortbed with a rear Chrysler 8.25 (should be the same for the Dana 44). I'm swapping to an auto transmission, so it might be about an inch too long for me now. I only have about 1k miles on it. I'd want more than someone with a factory shaft, but I could certainly do better than new.
The front shaft has room to slip, so is there a difference between the auto and stick?
