Can intermittent wipers be added?
Yes, that's a standard GM stalk. Pretty much any '80s GM car will work as a donor. The stalk just pulls out of the switch and then you have to disassemble the column to remove the switch. It's probably as much work to replace the switch as it is to swap the column...just depends on what you have available.
