I have the same exact wires not being used. I was told they are for the options I don't have. I used the long single red wire for the hot side of my fog light relay being that it is a constant hot.
If thats the one I think it is then it will start the truck if you plug it into one of them connectors with the key set to on then it will start the truck. :rotfl2: My dad said it is most likely a "left over" from some type of factory add on
Brandon
