Bigbike Posted December 8, 2010 Share Posted December 8, 2010 What kind of fluid goes in my pukegoat 5 speed? How much fluid Link to comment Share on other sites More sharing options...
mkbruin Posted December 8, 2010 Share Posted December 8, 2010 I think its 75w90, but you can use 80w90 (its cheaper). 2.5 quarts, IIRC (fill till it comes out the fill plug) And about the fill plug.... its a 8mm recessed square. Most people either shave down a 3/8 ratchet or cut up a 8mm allen. Take the fill/drain plugs to NAPA and swap with a standard fill plug if you intend on keeping the BA for a while. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted December 10, 2010 Share Posted December 10, 2010 I'm using Pennzoil "syncromesh". About 2.5 qts. Link to comment Share on other sites More sharing options...
