comanche12 Posted November 29, 2010 Share Posted November 29, 2010 I'm currently working on climate control system while waiting for brake lines shipment to arrive. I can't find the Blower Motor connector so wheres the location the connector is at? have to remove the dashboard? So the issue is that blower don't blowing at all in any speed range, i checked the resistor- its pretty in bad shape. I want to apply the volts to blower motor it self but can't find the connector for it. Link to comment Share on other sites More sharing options...
jeepdude89 Posted November 30, 2010 Share Posted November 30, 2010 The blower motor connector is under the hood on the passenger side, up by the firewall. The connector is very accessible, you will see the back end of the blower motor up in the corner once you open your hood. Link to comment Share on other sites More sharing options...
comanche12 Posted November 30, 2010 Author Share Posted November 30, 2010 The blower motor connector is under the hood on the passenger side, up by the firewall. The connector is very accessible, you will see the back end of the blower motor up in the corner once you open your hood. hmm is it should be right under the coolant expand bottle? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 30, 2010 Share Posted November 30, 2010 yes, it's under the coolant reservoir. a green and black wire to a connector. Link to comment Share on other sites More sharing options...
comanche12 Posted November 30, 2010 Author Share Posted November 30, 2010 thanks! hopefully ill find it as piece of cake Link to comment Share on other sites More sharing options...
comanche12 Posted November 30, 2010 Author Share Posted November 30, 2010 found it and the result is that i knew it that blower is dead. won't even blowing after apply the volt. but seem need small hand to able reach all those three bolts. :ack: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 30, 2010 Share Posted November 30, 2010 pull the reservoir tank strap off, move it out of the way, remove the support for the reservoir, and then remove it. Link to comment Share on other sites More sharing options...
comanche12 Posted November 30, 2010 Author Share Posted November 30, 2010 pull the reservoir tank strap off, move it out of the way, remove the support for the reservoir, and then remove it. ah didnt think about that! thanks!!! :thumbsup: Link to comment Share on other sites More sharing options...
comanche12 Posted November 30, 2010 Author Share Posted November 30, 2010 its removed like charm thanks for advice :thumbsup: Link to comment Share on other sites More sharing options...
comanche12 Posted December 2, 2010 Author Share Posted December 2, 2010 just let you guys know that i got my blower work by replaced the motor and new 12 gauges of wire for power from fuse to switch. all i need to replace later is resistor and climate control dash board because previous owner cut the vent for windshield defrost :doh: Link to comment Share on other sites More sharing options...
