Ball Joint Replacement
Wheels, calipers, rotors, hubs and axles (remove hub and axle shaft as a unit without removing the big axle nut), steering knuckle. Rent, borrow or buy a ball joint press tool. It can be done using just a BFH, but it is WAAAAY easier with the right tools.
