ParadiseMJ Posted November 19, 2010 Posted November 19, 2010 88 MJ Pioneer, 5 speed, 4.0, 4x4 Are the wipers and the radio on the same circuit?? They both took a dump on me at the same time. The circuit breaker for the wipers tested fine...is there a fuse?? Also the "PART TIME' light is on when it's not in 4x, and goes off when I put it IN 4x. Still a work in progress
ParadiseMJ Posted November 21, 2010 Author Posted November 21, 2010 No, really, this is an issue for me. Can anybody help a bro out??
Pete M Posted November 21, 2010 Posted November 21, 2010 any evidence of brake fluid in the fuse panel?
ParadiseMJ Posted November 21, 2010 Author Posted November 21, 2010 any evidence of brake fluid in the fuse panel? No. I've checked that several times since I got the thing. I just put in the floor insulation and rubber mat and saw nothing.
Suuperman Posted November 21, 2010 Posted November 21, 2010 I think it's your ignition switch on the column up under the dash. My '90 XJ did exactly this...cranked and ran fine but those items and a few more were out. Fuses were good. But on my ignition switch there was a bad spot. I am guessing it is the keyed source that 'completes' the circuit allowing 12V to go to those things. Replaced the switch and no problems since.
ParadiseMJ Posted November 22, 2010 Author Posted November 22, 2010 I think it's your ignition switch on the column up under the dash. I think you may be right. I've had a few gremlins that point to the switch. I have the switch, I just put the dash back together. #@&* if didn't replace it before. :doh: I'll get back when I have the time to install it.
