Getting Ready for Winter... Garage Heater
Carl'sMJ
Installed it a few weeks ago and figured I'd share... It's a Fahrenheat 5000 watt ceiling mounted electric heater. It's rated for 17,065 BTU output and runs on 240V. I bought it from Northern Tool.
http://www.northerntool.com/shop/tools/product_595_595
I was fortunate to already have a 240V circuit and breaker panel in the garage which made installation a bit easier.
I've only used it a couple times since I put it in and it worked well, but the weather wasn't that cold. I'm curious to see how well it heats once the middle of Michigan winter hits. I think it should do well enough to take the edge off anyway. My garage is about 20' x 30' and is completely insulated.
Yeah, I was curious about it too. I think as long as don't expect the thing heat beyond its intended means and set the thermostat at a reasonable temp I should be OK.
I opted for electric over natural gas for a couple reasons. Primarily because I already had the 240V circuit and breaker panel in the garage, so convenience and ease of installation right off the bat. Plus, if I don't have to work with gas I'll avoid it. The electric set-up is probably safer and I don't have to worry about leaks and such.
I'm in the same boat, got natural gas at the house but not out at the garage. I do however, have 240 vac with spare space in my panel so electric might not be such a bad option.
