kawaboy13 Posted November 10, 2010 Share Posted November 10, 2010 What should I check for? I put 2 wires from the license plate lights together and everything went out. Help? Link to comment Share on other sites More sharing options...
WBKrazy Posted November 10, 2010 Share Posted November 10, 2010 most likely you haz blown a fuse...check all those first.. Link to comment Share on other sites More sharing options...
kawaboy13 Posted November 10, 2010 Author Share Posted November 10, 2010 So I got all my lights to work (changed fuse) Then my brake lights blew9changed fuse) so they wrok. But now when I close my door, my b-pillar light stays on unlike before. I have no idea what to do. This is driving me crazy Link to comment Share on other sites More sharing options...
tbrand Posted November 10, 2010 Share Posted November 10, 2010 The B-pillar lights are a 3-position switch - mine don't work, but they can be always on, on when the doors are open, or totally off, depending on which position the light is in. Try rotating the lens up or down. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted November 10, 2010 Share Posted November 10, 2010 What should I check for? I put 2 wires from the license plate lights together and everything went out. Help? Those license lights (on mine anyway) were just a single wire, one for each side of the plate, the ground is in the mount. Link to comment Share on other sites More sharing options...
