com_mako Posted November 9, 2010 Posted November 9, 2010 hello alls does someone remember on what jeep those mags wheel came from ?? the seller is telling me that they are 15x8 but I am not sure http://www.quebec4x4.com/forum/showthread.php?p=785904#post785904 thank!!
Automan2164 Posted November 9, 2010 Posted November 9, 2010 They came from a late '80's / Early '90's Wrangler, Comanche, or Cherokee. Not sure on the size, I thought it was 15X7. Should be bolt on nonetheless. Rob L.
HOrnbrod Posted November 9, 2010 Posted November 9, 2010 Rob is correct, 15x7. http://colorado4wheel.com/jeepwheels/xjwheels.html
com_mako Posted November 9, 2010 Author Posted November 9, 2010 :mad: hate those that don't know the difference between 7 and 8 !! :nuts: simple! no?
jpnjim Posted November 10, 2010 Posted November 10, 2010 People who measure 15x7's as 8's are usually are just measuring from the wrong location. Outside to outside, 7" wheels measure ~8" wide, (tire mounts inside the wheel so that's where they should be measuring from). It does get confusing when you measure backspacing tho, since for backspacing you DO measure to the outside of the (inner) wheel edge (wheel mounting surface to outside of backside of wheel, if that makes any sense). But yeah, those wheels are 15x7, with the typical 5.25"BS.
