Incommando Posted November 8, 2010 Posted November 8, 2010 I have picked up what I believe to be a factory roll bar out of a SWB Chief but I am not sure of the correct way to mount it. It has studs out of the bottom of the "feet". Any help, especially pics and or measurements if needed, would be appreciated.
HOrnbrod Posted November 8, 2010 Posted November 8, 2010 Below is a pic of the factory bar. If it has studs on the feet, it's not factory, unless someone put them there. Can't imagine why anyone would do this though........ :dunno: Image Not Found
Automan2164 Posted November 8, 2010 Posted November 8, 2010 The factory roll bar is attached to the wheel wells with plates on the inside of the wheel well, and bolted down to a factory roll bar tie in to the frame under the bed to support the main hoop. Rob L.
Incommando Posted November 9, 2010 Author Posted November 9, 2010 Well, I have no idea what I have. It fits perfectly and is assembled using T55 torx bit "nuts" that slide over carriage bolts to attache the down bars to "feet" bolted to the sheet metal. Definitely not a true "roll bar" and no apparent provision for a frame tie-in. Pics toooomorrow.
