shifter change
Anyone ever change a column shift to a floor shift for an auto???
I'm suppose to be picking up a 91 manche with an ax15, so i thought i could use the shifter set up then use an XJ shifter. i know i will have to change the column, but is it as simple as i am thinking it will be??
the tcu controls all shifting. The only thing the range selector does is tell the trans wheter it's in park, reverse or forward. Grab a console shifter and it's cable, should bolt right up to your aw4, you don't even have to mess with any wires, it's all mechanical.
