Rokhound Posted November 18, 2006 Posted November 18, 2006 will these work on my truck 87 with 6" lift please let me no http://cgi.ebay.com/ebaymotors/Fabtech- ... dZViewItem
feerocknok Posted November 18, 2006 Posted November 18, 2006 According to Fabtech's catalog, there are 3 different disconnects. One for a 4" TJ, one for a 6 or 8" TJ, and one for 4" XJ/MJ. So, for one reason or another, the 4" TJ model is different than the 4" MJ model. That leads me to believe that a 6" TJ model would be different than the nonexistant 6" MJ model.
87manche Posted November 18, 2006 Posted November 18, 2006 they should work, I've looked at my neighbors TJ, the front axle is identical. JKS shows the same part numbers for tj/xj/mj, so I don't know why another manufacturer would be different.
Rokhound Posted November 18, 2006 Author Posted November 18, 2006 so if they don't go to high buy them and see. i think that is the plan if they don't fit then i will sell them i guess but if they do fit we will all no :D
CWLONGSHOT Posted November 18, 2006 Posted November 18, 2006 You could make them work. BUT know that the bolt will rub on the side of the TB bracket. For clearance on the MJ XKJ. You need a longer "U" section OR a flat head bolt. like a "carrage" style for more clearance. I use the Skyjackers for a XJ and find the rubing VERY anoying to the point I have been running WO my front bar attached!! Now that its colder and the windows are up, I'll likely reconnect. I can be kind of anal about noises from my Jeeps. CW
