freakjeep93 Posted October 13, 2010 Posted October 13, 2010 not on my jeep don't worry...... a couple months ago my car (2001 hyundai elantra) started having tranny problems. i took it of the road before it got really bad and got my moms old 98 elantra. anyway these are the symptoms: at idle there is a rattling/clunking noise coming from the transmission that gets faster with rpm. sometimes while driving it will let a sudden snap out of the transmission, no jumping out of gear /increased rpms just a sudden pop then back to normal. and lately afer moving forward in 1st gear when you shift to reverse it will make the above mentioned sound after you move a couple feet. my step father told me it may be a loose or cracked flex plate but i want to be sure before i tear it apart. the car is a 2001 hyundai elantra 5 speed. i know its not jeeps but i know theres a couple machanics on here that might be able to help. thanks in advance
mvusse Posted October 13, 2010 Posted October 13, 2010 May very well be. My XJ was doing the rattling, but no clunking or popping/ Turned out all 4 bolts holding the torque converter to the flex plate had backed out a few turns.
