AX15 4WD shifter bracket for 92 MJ
I left a link to car-part.com in earlier post for stock linkage.
You could post a "Wanted" in the appropriate section.
Or you could buy one of these http://www.novak-adapt.com/catalog/kit_sk2x.htm
Yeah I know I could post it in the "wanted", and Cheyenne, I tried car-part.com for Cherokee and Comanche and I had no luck. I'm going to my shop now and asking them if these custom ones you posted will work. Thanks
"main part"?
I pulled a linkage system out of a MJ with a different transmission, but he bracket that bolts it on doesn't seem to link up correctly.
Anyway, enough of that;
I just want this linkage system I ordered to work so I can take my MJ out wheeling for the first time. It's never been off road before. My transmission is the AX15 5-speed manual and I noticed it's an automatic in the picture which is worrying me a little, also my transfercase is a NP231 J? or something. Oh well, I've got smart friends with a shop and all the MJ addicts here on the forums.
:rant:
that flat bar in the pic is my bracket. all you really need is a sturdy point in space directly across from the pivot point on the body bracket.
:thumbsup:
Yeah, but I'm still using the one I ordered because the MJ I pulled it out of is drivable and in need of very little TLC so I didn't want to use it for parts and now I don't need to :)
So they just forgot to send you the bracket? Or it doesn't come with it?
