Rymanrph Posted September 29, 2010 Share Posted September 29, 2010 I got the dash off of the '97 today and found this broken piece on the heater box: There is a similar one underneath that moves the shutter, but what does this one do and can it be fixed? It looks like it broke on the end, but I don't know the natural orientation to reassemble it. Link to comment Share on other sites More sharing options...
shark Posted September 29, 2010 Share Posted September 29, 2010 you should ask over at naxja. most guys over here havent done the dash swap. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted September 29, 2010 Share Posted September 29, 2010 Looks to me like a broken mode door shaft. If so, youre pretty much screwed. If you have the unit out of the truck, pull the unit top off and check the mode doors there. At the very least, youll need a new door put in, at most you might need a whole new housing. Good luck Link to comment Share on other sites More sharing options...
Rymanrph Posted September 29, 2010 Author Share Posted September 29, 2010 Looks to me like a broken mode door shaft. If so, youre pretty much screwed. If you have the unit out of the truck, pull the unit top off and check the mode doors there. At the very least, youll need a new door put in, at most you might need a whole new housing. Good luck Great. I looked today and its the shutter on the top. Its always down. Hopefully I can get a better look at it once I get it out of the truck. Link to comment Share on other sites More sharing options...
