2.5 oil pan gasket
pug
I don't think you absolutely have to, but it would certainly make it easier. I can understand why you wouldn't want to, those torx bolts are a pain.
You'll need a little bit of sealer if you get a rubber gasket - pretty sure they have those for the 2.5. I HIGHLY recommend not using a cork gasket.
Why are you removing the pan?
