90comanche Posted September 23, 2010 Share Posted September 23, 2010 does anyone know if gabriel highjacker air shocks bolt up to the 1990 comanche 4x4 shock brackets? Link to comment Share on other sites More sharing options...
Comanche County Posted September 23, 2010 Share Posted September 23, 2010 No clue, if both ends are the same type as an MJ's and they're relatively the same length then they should. Check out their website or call em up and ask. From the pic on their website it looks like they might. I'm sure they have an application for an XJ or MJ, just remember MJ rear shocks are longer than XJs. http://www.gabriel.com/ Link to comment Share on other sites More sharing options...
carnuck Posted September 24, 2010 Share Posted September 24, 2010 If it's not lifted, yes. Link to comment Share on other sites More sharing options...
90comanche Posted November 3, 2010 Author Share Posted November 3, 2010 sweet thanks guys. have u ever seen anyone bolt them to the front? Link to comment Share on other sites More sharing options...
danbyrambler Posted November 5, 2010 Share Posted November 5, 2010 From the Monroe charts at http://www.monroe.com/catalog/documents/08_MountingLengthSheet.pdf - This site has ALL the specs; bushings,stems,thread-everything-good info - - - - Listed for my '87 MJs rear shocks - Monroe sensa track shock part # 37029 - Upper mount=L1 Lower mount=L1 Compressed length=14.375 Extended length=23.000 Travel length=8.625 - - Then, from the Air shock chart - the specs for Part # MA820 are the same - with the exception of no dust shield - So...should be straight bolt on - Easy enough to search the specs if you want bigger/smaller/longer or whatever for non standard app - May have to swap bushings when getting creative - - '87 MJ front shocks part #37026 specs are S4 XP4 12.875 20.375 7.500 Yes P1136 & then from the air shock list - No exact match but # MA763 with specs of S4 XP5 12.125 20.125 8.000 None P1136 is very close - should be easy enough & ok - The Gabriel site has similar info but not as easy to use IIRC - Hope this helps - Link to comment Share on other sites More sharing options...
