Coil Spring Question
JK wrangler ones will, same diam and similar length, but probably stiffer due to being in a heavier vehicle.
From the factory the JK uses 22 different coil springs, each with a slightly different spring rate; dictated by how the JK is equipped. It's honestly so hard to tell what kind of results you'd get from a JK coil.
