Waytec Posted September 12, 2010 Share Posted September 12, 2010 Thank You for the help everyone on the XJ 4.0 swap that is coming up shortly. To the point here. I picked up a 2 wd "parts MJ" a couple weeks ago for the price of the tow to the guys house from where it died. I finally had a change to go over it and have a good look. Man is it in good shape. very little to no body work needed. the cab corners are perfect, the floors are solid carpet is dirty but that should shampoo out. in issue is it has a 4 banner that is toasted, and it has the basic interior, bench seat, and a gage pod that only has fuel and speed. what is involved in swapping a 4.0 in, all the 4wd stuff and the gage pod out of my 90 eliminator (with a trashed body) into the 88. I know this has been done and there is write ups, could you just give me the links please and any tips for the job. Thanks Link to comment Share on other sites More sharing options...
Eagle Posted September 12, 2010 Share Posted September 12, 2010 Is the 4-banger an '86, or newer? Link to comment Share on other sites More sharing options...
Waytec Posted September 12, 2010 Author Share Posted September 12, 2010 It is out of an 88 I am guessing I am going to have to take the computer and wiring harnesses from the 90 I6 in order for that to run. Link to comment Share on other sites More sharing options...
Eagle Posted September 12, 2010 Share Posted September 12, 2010 It is out of an 88 I am guessing I am going to have to take the computer and wiring harnesses from the 90 I6 in order for that to run. Correct. But at least the firewall won't have to be modified. You'll also need the front radiator supports, and the 4.0L radiator. Also, the 4.0L weighs a lot more, so you'll have to swap the front springs. Link to comment Share on other sites More sharing options...
mjeff87 Posted September 12, 2010 Share Posted September 12, 2010 viewtopic.php?f=7&t=11205 Jeff Link to comment Share on other sites More sharing options...
Waytec Posted September 12, 2010 Author Share Posted September 12, 2010 The plan is to the 90 that I am driving right now will be parts donor for the 88. the 90 will be donating the harness, gage pod, rad supports, D30, transmission and transfer case. Link to comment Share on other sites More sharing options...
Waytec Posted September 22, 2010 Author Share Posted September 22, 2010 I am swapping a gage pod out of 90 MJ 4x4 4.0L into a 88MJ 2.4 2.5L as well. I know I will have to take the harness but I will I have to take the interior harness as well? Link to comment Share on other sites More sharing options...
