pug Posted September 11, 2010 Share Posted September 11, 2010 Has anybody used thishttp://www.eastwood.com/autobody/seam-sealer.html Link to comment Share on other sites More sharing options...
dasbulliwagen Posted September 11, 2010 Share Posted September 11, 2010 http://www.eastwood.com/autobody/seam-sealer.html Fixed it for you. I have used similar products in the past. This stuff is more like what the factory uses than anything else out there. It will fill bigger gaps, dries firm but not hard, and is paintable. Link to comment Share on other sites More sharing options...
valis Posted September 11, 2010 Share Posted September 11, 2010 I've used stuff similar, but not necessarily made by Eastwood, although they do put out some good products. It has worked very well on my MJ and YJ floorpan repairs and, as mentioned above, is completely paintable. If you look close, you can see the seam sealer smeared around the edges of the patch panels I put in my MJ floor: A word of warning with this stuff - It is POTENT. If you're going to apply it, do it outside or in a well ventilated area. If neither of those are possible, which was the case with me, buy a respirator. I got a cheap, but good one online for around $25. This stuff will knock you out if you're working in a small cab like an MJ. Link to comment Share on other sites More sharing options...
dakal Posted September 11, 2010 Share Posted September 11, 2010 eastwood good stuff. you get what you pay for. Link to comment Share on other sites More sharing options...
pug Posted September 11, 2010 Author Share Posted September 11, 2010 Thanks i will try. Link to comment Share on other sites More sharing options...
