short bed rear drive shaft
duhast720
Get a measurement between the tcase and rear diff. Put your old driveshaft into the tcase and measure from the center of where the U joint would normally sit and where it sits at the rear end with the truck sitting normally. (I push the driveshaft into the trans all the way and pull back @ 1 1/2" before measuring to allow for travel)
Are you going to put in a slip yoke eliminator?
