Nate C Posted August 22, 2010 Share Posted August 22, 2010 Replaced everything in the rear, New seals, bearings, backing plates, drum kit, shoes, rotors, brake lines ect ect ect. original master cyc front valve, and the thing in the back,.... height or load valve I think. So I had a panic stop a few days back,... notice the truck took a bit more distance to to stop than I feel comfortable with. My Ebrake needed adjusting anyway so we took a look at it. Jacked up the back, adjusted the cable for the Ebrake on the bracket under the bed and with the little metal wheels inside the backing plate. Wheels still turn with a bit of effort,... this with the Ebrake to the floor. So tried the main brake,.... same result. The wheels spin with the same resistance or lack there of :eek: Bled the line,... a little air in there. Started the truck to get the booster/vacuum going. No good,... wheels can be turned by hand without a lot of effort. More difficult to turn them backwards than forwards. :hmm: I'm stuck,... don't know what else to try here. Bad valve somewhere? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 22, 2010 Share Posted August 22, 2010 Sounds like what happened to you also happened to Eagle - blew out the load sensing valve on a panic stop. Hopefully he'll chime in here. Were the rears working okay until the panic stop? Link to comment Share on other sites More sharing options...
gl1200aman Posted August 22, 2010 Share Posted August 22, 2010 Have you checked the star-wheel adjuster? That adjusts the bottom of the pads out as they wear. the cable and hydraulics can only move the pads so far and the star-wheel adjusts to compensate. Link to comment Share on other sites More sharing options...
Nate C Posted August 24, 2010 Author Share Posted August 24, 2010 I don't think those rear brakes have worked for quite a while,... just haven't gotten around to it. Figured it was stopping pretty well I'll play with them later. The near fender bender put it up towards the top of list though. That and the E-brake can't stop a stiff breeze. I did try the star wheel,..... cranked on it for a while,.... no effect. the main brake will not stop the rear wheels either. jacked up the back started the truck in neutral, stomped on the main brakes and the rear wheels could still be turned by hand. Bled the lines,... no effect :dunno: Link to comment Share on other sites More sharing options...
Nate C Posted August 24, 2010 Author Share Posted August 24, 2010 If get rid of the valve in the back could that solve my problem? Just run a straight line? If I do that will it affect my stopping power while under load or towing a boat? Link to comment Share on other sites More sharing options...
gl1200aman Posted August 24, 2010 Share Posted August 24, 2010 If you have the e-brake adjusted and they don't work that well either it is inside the drum. Pull the wheels and drums and see what you have. Pads or drums may be worn, check to see if the star wheel is working (each turns a different way), or parts missing. There is the flat bar between the pas that may have slipped/fell out. Link to comment Share on other sites More sharing options...
