comanche12 Posted August 21, 2010 Share Posted August 21, 2010 after I fixed my vacuum hoses to keep engine run proper and unnecessary to feed gas all the way to keep engine alive, it runs much better. but it died after test with highbeam which it draw enough amp from battery then engine died. so do u think its possible because of battery to die after testing with the highbeams? Link to comment Share on other sites More sharing options...
cracker Posted August 21, 2010 Share Posted August 21, 2010 after I fixed my vacuum hoses to keep engine run proper and unnecessary to feed gas all the way to keep engine alive, it runs much better. but it died after test with highbeam which it draw enough amp from battery then engine died. so do u think its possible because of battery to die after testing with the highbeams? You are asking that is it possible for the battery to die when the high beams are on? Yes but not with a functioning (or properly operating) alternator. Link to comment Share on other sites More sharing options...
comanche12 Posted August 21, 2010 Author Share Posted August 21, 2010 after I fixed my vacuum hoses to keep engine run proper and unnecessary to feed gas all the way to keep engine alive, it runs much better. but it died after test with highbeam which it draw enough amp from battery then engine died. so do u think its possible because of battery to die after testing with the highbeams? You are asking that is it possible for the battery to die when the high beams are on? Yes but not with a functioning (or properly operating) alternator. hmm alright thanks. battery isnt cheap :( is there any way trick to buy battery for cheap like 50 bucks than 70-100ish? Link to comment Share on other sites More sharing options...
Automan2164 Posted August 21, 2010 Share Posted August 21, 2010 after I fixed my vacuum hoses to keep engine run proper and unnecessary to feed gas all the way to keep engine alive, it runs much better. but it died after test with highbeam which it draw enough amp from battery then engine died. so do u think its possible because of battery to die after testing with the highbeams? You are asking that is it possible for the battery to die when the high beams are on? Yes but not with a functioning (or properly operating) alternator. hmm alright thanks. battery isnt cheap :( is there any way trick to buy battery for cheap like 50 bucks than 70-100ish? Easy killer. You need to figure out if you have proper charging voltage before you pull out the parts shotgun. Check your voltage with the Jeep running, and let us know what it is. Rob L. Link to comment Share on other sites More sharing options...
comanche12 Posted August 21, 2010 Author Share Posted August 21, 2010 well i know but its for sure its battery. i took it to autozone and its rehcarge and its not good plus when i got it tow from my friends home to my home. someone idiot put headlight on while tow it so he discharge my battery full way all the way to my home so its hard to rechargemy battery second... i don't have voltmeter :( its died on me Link to comment Share on other sites More sharing options...
Automan2164 Posted August 21, 2010 Share Posted August 21, 2010 well i know but its for sure its battery. i took it to autozone and its rehcarge and its not good plus when i got it tow from my friends home to my home. someone idiot put headlight on while tow it so he discharge my battery full way all the way to my home so its hard to rechargemy battery second... i don't have voltmeter :( its died on me You should pick one up. If the truck was running at the time you had the lights on like you said, then died, the alternator was most likely toast. You'll just cook another battery if you put the new one in and try again without checking the system. Rob L. Link to comment Share on other sites More sharing options...
mvusse Posted August 21, 2010 Share Posted August 21, 2010 Most auto parts stores will test your alternator for free. Can't hurt to remove it and have it tested. Link to comment Share on other sites More sharing options...
comanche12 Posted August 21, 2010 Author Share Posted August 21, 2010 well i know but its for sure its battery. i took it to autozone and its rehcarge and its not good plus when i got it tow from my friends home to my home. someone idiot put headlight on while tow it so he discharge my battery full way all the way to my home so its hard to rechargemy battery second... i don't have voltmeter :( its died on me You should pick one up. If the truck was running at the time you had the lights on like you said, then died, the alternator was most likely toast. You'll just cook another battery if you put the new one in and try again without checking the system. Rob L. i know I'm still in budget to save money i means engine still running while light is on (lowbeam, other lights) then switched to highbeam... engine died i just replaced my alternator. its been test and its passed. :hmm: Link to comment Share on other sites More sharing options...
shark Posted August 21, 2010 Share Posted August 21, 2010 a multimeter is cheap at harbor freight. like $5 on sale. a u-pull-it yard will be cheap for a alternator and battery. i got a nearly new autocraft silver for $25 at my local yard a few weeks ago. Link to comment Share on other sites More sharing options...
comanche12 Posted August 22, 2010 Author Share Posted August 22, 2010 a multimeter is cheap at harbor freight. like $5 on sale. a u-pull-it yard will be cheap for a alternator and battery. i got a nearly new autocraft silver for $25 at my local yard a few weeks ago. i dk which is junk yard to go. too many around me and dk which one have mj or xj :( well is it functional well not just false reading? Link to comment Share on other sites More sharing options...
Eagle Posted August 22, 2010 Share Posted August 22, 2010 i dk which is junk yard to go. too many around me and dk which one have mj or xj :( Link to comment Share on other sites More sharing options...
Automan2164 Posted August 22, 2010 Share Posted August 22, 2010 i dk which is junk yard to go. too many around me and dk which one have mj or xj :( Phones had cords? How the hell do you dial that? Where are the buttons? Rob L. ;) Link to comment Share on other sites More sharing options...
comanche12 Posted August 22, 2010 Author Share Posted August 22, 2010 i dk which is junk yard to go. too many around me and dk which one have mj or xj :( Phones had cords? How the hell do you dial that? Where are the buttons? Rob L. ;) lol good one but I'm gonna win... I'm myself a deaf........ :no: just kidding i know many way to get phone call :) I'm too lazy to call haha thats me. Link to comment Share on other sites More sharing options...
Automan2164 Posted August 22, 2010 Share Posted August 22, 2010 I still think that before you replace everything you NEED to figure out if all systems are go in the truck. Buy, borrow, or steal a voltmeter before ya drive me batty, and check the system. For all you know it could have just been a loose wire/cable, and your throwing parts at it wasting money. http://shop.ebay.com/?_from=R40&_trksid ... Categories A DVOM is one of those tools one should not be without. :smart: Rob L. Link to comment Share on other sites More sharing options...
comanche12 Posted August 22, 2010 Author Share Posted August 22, 2010 :agree: I'm planning to get multimeter tomorrow i hope and one of my other friend with chrsyler sebring offer me free of his battery :) after plan to destroyy his pos sebring Link to comment Share on other sites More sharing options...
