4.0 V.S. 4.2 ?
I have a 89 4.0 Renix motor out of a Cherokee for sale. A guy wants to buy it and put into his 78 CJ5 Does anybody know what the difference is, he is wondering if the heads are the same? And could he bolt his intake and carb to my Head? His motor is a 258 4.2. I'm not sure if he plans on using the whole motor or just the head, so the question is will and intake from a 4.2 bolt to a renix 4.0? Thanks again
A lot of people with the 4.2L will buy the head and intake to convert it to fuel injection. If I remember correctly, the 4.2 and 4.0 are the same minus the crank and rods. I know everything on the outside swaps between them.
The budget build 4.5 stroker is just a 4.0 with 4.2 crank and rods.
http://jeep.off-road.com/jeep/news/42l- ... 29337.html
That's a great link about the head conversion if you're interested in reading material. I did a little research on google about the intakes and one person says it will fit with minor modifications and the other says it's a direct bolt up. So if you have the skills to install the engine, swapping the intake manifold over won't be an issue.
