Alright guys,
I visited my Comanche again (in Alabama) and I crawled under it, and I see oil EVERYWHERE! Like all around the engine.. What could cause this?
My '89 2.5L does the same thing, and I think it's pushing it out the dipstick tube at higher RPM's. Also check the oil gauge sending unit just fore of the distributor.
Check the valve cover. If thats leaking it will be running down the block from there, and cover everything. Also, any breather tubes that are no longer attached to the air box or a bad oil cap can spew out. My money is on the valve cover though.
Rob L.
There is gunk around the valve cover... But I don't even drive it and its leaking really bad... What is the hose connecting on top, near the valve cover, I did see some oil around there.
would be breather or something else? :hmm:
