Akula69 Posted August 13, 2010 Posted August 13, 2010 Am looking for a new prop valve (or operating used one) Thanks Jake
Akula69 Posted August 14, 2010 Author Posted August 14, 2010 You mean no one has an extra prop valve?!?
87Warrior Posted August 14, 2010 Posted August 14, 2010 I have one from my 92 project. won't be using the prop valve as my project evolves. It is not blown out and does not leak. My brakes always worked fine, but I do not know if it 'works' as designed. Want it? I can pull it tomorrow. Do you need the axle rod/plate assembly? $35 shipped?
Akula69 Posted August 14, 2010 Author Posted August 14, 2010 Thanks, but after looking at the parts list it appears that I can use one from a 87 to 89 model, the 90 to 92 model prop valves are a different part number.
