cant find a speedo cable!!
I went to oreillys and they gave me one for a 4 Banger that didn't even plug into the cluster... took it back and didn't list one for a I6... so he called the dealer... discontinued... where the crap can I get one? 89 Comanche... 4x4... ax-15... 231... short bed... thanks again!
There is no difference between the 4-cylinder and 6-cylinder speedometers. There IS, however, a difference between the early (thru 86, and maybe part-way into '87) speedo and the '87 thru '90 speedo. The early type has a metal end on the cable that attaches to the speedo head with a screw. The later type has a white nylon end on the cable and it just snaps over the fitting on the speedo head.
mine just snaps in and out... well it did till the plastic broke... lol... i know there "shouldnt" be a difference between 4 and 6 cylinders... but thats what there computer came up with... the one it "showed" for the 4 banger was half the length of my stock one... and the into 94 it says there is two cables that connect to each other... heck i dunno...
ill check that out above man thanks!
Travis
Well, the '94 had an electronic speedometer, so it didn't use any cable.
Try a different store, with a smarter computer.
