jackenacker Posted August 4, 2010 Share Posted August 4, 2010 1986 one ton with spring over in rear I need HD springs for the front extra weight from pipe bumper brush guard and winch. I need about 7" of lift on the front.The front has long arm,and new track bar. Link to comment Share on other sites More sharing options...
Pete M Posted August 4, 2010 Share Posted August 4, 2010 what other lift parts are you using up front? Link to comment Share on other sites More sharing options...
Incommando Posted August 4, 2010 Share Posted August 4, 2010 http://motionoffroad.com/catalog/index. ... ts_id=1136 There are other sources out there, but here is one example. A small spacer lift may need to be added to fine tune the lift if that bumper combo is extra heavy. I am sure that it goes without saying that getting the jeep 7" higher with the bumper is the easiest part of making a 7" lift work. Link to comment Share on other sites More sharing options...
