wannabeMJ Posted July 21, 2010 Share Posted July 21, 2010 here is where I'm at ...... any sugestion on what I should do with this its the last thing to do before I start the paint job....... Â should I cut and weld or ????????? Link to comment Share on other sites More sharing options...
philbert001 Posted July 21, 2010 Share Posted July 21, 2010 Drill the spotwelds on the seam, and cut back till you are passed the rust, then make a patch that'll extend under the original metal 1/4 inch, then weld her in. Keep your spot welds 2 inches apart, and make several passes to keep the heat and warpage to a minimum. Mud it, block it, prime it, and paint it! Link to comment Share on other sites More sharing options...
wannabeMJ Posted July 21, 2010 Author Share Posted July 21, 2010 seams I haver no other choice :wall: :wall: :wall: Link to comment Share on other sites More sharing options...
