ParadiseMJ Posted July 8, 2010 Posted July 8, 2010 Like the title says...so I'm replacing the diff oil. The PO said the front D30 had an LSD, but I've never heard of a stock (or otherwise) LSD on a 30. Is the PO just blowing smoke? The rear D44 does have the LSD and the tag to prove it.
Geonovast Posted July 8, 2010 Posted July 8, 2010 I've heard of some WJs having them. Pop the cover and take a look.
Eagle Posted July 8, 2010 Posted July 8, 2010 The XJ and MJ never came from the factory with any form of "traction device" in the front axle. Smoke.
Geonovast Posted July 8, 2010 Posted July 8, 2010 Eagle, are you saying that WJ D30 trac lok could never have been installed in an XJ/MJ D30? There's a possibility it has it, however unlikely. Best way to find out is to pop the cover.
Incommando Posted July 8, 2010 Posted July 8, 2010 Factory- not on the XJ/MJ There are aftermarket options that could have been swapped in.
