87Chief Posted July 3, 2010 Share Posted July 3, 2010 Hey everyone, I have a 1987 Jeep Comanche Chief and I was looking under the hood when I saw a lot of oil/gunk around the engine, (cover?), would that mean a new gasket would be needed? I'm not sure what it is called, I'm new, but I think it is the engine cover gasket or something? Maybe the valve cover and some oil gets all gunky (lol), but what would be something good to clean the outside with? Thanks for all the help! Mike Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 3, 2010 Share Posted July 3, 2010 GUNK and many others make spray on engine cleaner. It works quite well with a warm engine and a hose. just don't directly spray the electrical or the distributor. It may take a couple applications and even a good stiff brush and scrapers. Once clean yes change out the valve cover gasket and check the "O" rings on the oil filter adaptor as well. Any other leaks will also become apparent once your cleaner... CW Link to comment Share on other sites More sharing options...
88SporTruck Posted July 4, 2010 Share Posted July 4, 2010 Change your valve cover gasket. I changed mine and the flood of oil down the side of the engine has slowed to a trickle. That trickle being caused by the POS plastic valve cover on my 88 being cracked. Your engine should have some grime on it but if you clean it nicely then it should stay clean. Oil leaking down the side of the motor is probably the valve cover gasket. don't't cheap out. Get the expensive gasket. It's worth it. Link to comment Share on other sites More sharing options...
87Chief Posted July 6, 2010 Author Share Posted July 6, 2010 Ok, what is the best brand of engine cleaner?? And also, my MJ runs on the AMSoil system... Is anyone familiar with that? It does burn oil, but not much at all... Link to comment Share on other sites More sharing options...
