MancheKid86 Posted June 27, 2010 Share Posted June 27, 2010 they are all out, what could cause this? could it be the cleaning of the wiring harness that goes onto the front grill did something? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 27, 2010 Share Posted June 27, 2010 check your grounds, or r your beadlight switch howd u clean it? Link to comment Share on other sites More sharing options...
MancheKid86 Posted June 27, 2010 Author Share Posted June 27, 2010 sand paper Link to comment Share on other sites More sharing options...
MancheKid86 Posted June 29, 2010 Author Share Posted June 29, 2010 grounds as in sockets? checked driverside ground, ran a new ground directly to the frame from the battery, checked the fuses they are all in tact, should i check all the other light sockets? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 29, 2010 Share Posted June 29, 2010 i just fixed mine...it was my ignition switch, and a pain in the ars.....id check your headlight switch first though Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 29, 2010 Share Posted June 29, 2010 there's a reason that there all not working which makes me think its one of the two switches, not anything individual like a socket.....just my 2 cents Link to comment Share on other sites More sharing options...
MancheKid86 Posted June 30, 2010 Author Share Posted June 30, 2010 my ignition has a baaaad tumbler, takes a bit to turn the key over some times, and my highbeam switch works, even the highbeam light on the dash pops on, just no highbeams (lows work, and dimmer on dash works), i upgraded my front grill from an 86 to a 92, could it have diffrent wiring for the highbeams? or highly unlikely? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 30, 2010 Share Posted June 30, 2010 idk but it sounds like your switch needs adjustment..tumblers are like $10 at parts store too. id start with the adjusting of the switch, then see. Link to comment Share on other sites More sharing options...
Wildman Posted July 1, 2010 Share Posted July 1, 2010 my ignition has a baaaad tumbler, takes a bit to turn the key over some times,and my highbeam switch works, even the highbeam light on the dash pops on, just no highbeams (lows work, and dimmer on dash works), i upgraded my front grill from an 86 to a 92, could it have diffrent wiring for the highbeams? or highly unlikely? When you swapped out to the '92 header, did you use that header harness??? The '86 has some odd wiring, even different from the '87-'90 Renix era. Then you jumped to the '92 (HO era) and that wiring is completely different from the Renix era. If you want to leave the '92 harness in place, your going to have to trace down each wire/function, and splice it into the '86 harness, You'll need both wire diagrams to do this. Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 1, 2010 Author Share Posted July 1, 2010 i used the original wiring harness edit: i noticed that the brakes are on all the time once i pull the highbeam/dimmer they turned on and stayed on, i am going to replace my highbeam switch, my fuses and my hazard/turnsignal blinkers on my fuse box Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 2, 2010 Share Posted July 2, 2010 try your headlight switch Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 2, 2010 Author Share Posted July 2, 2010 okay ill get that too :D (edit:lmao wait thats what i meant for highbeam XD thought it didnt look right :shake: ) Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 4, 2010 Author Share Posted July 4, 2010 got it fixed :D some how i was missing my highbeam wire, so i spliced one into the system, put a new heavy duty blinker fuse in for a waste disposal truck XD found a melted part of the fuse box with a blown fuse, but we were able to jam a fuse in all in under 2 hours :D Link to comment Share on other sites More sharing options...
