87 comanche Posted June 17, 2010 Posted June 17, 2010 JUST PUT AX-15 IN ABOUT SIX MONTHS AGO. TRUCK SITS MOST OF THE TIME GOT IN THE OTHER DAY AND DIDN'T WANT TO GO INTO GEAR. POPPED THE HOOD AND CLUTCH RESIVOIR WAS ALMOST EMPTY. :fs1: AUTOMATIC WOULD BE NICE. FILLED RES GOES INTO GEAR FINE CLUTCH IS SOFT NOW. BRAND NEW CLUTCH AND SLAVE WITH AX-15 SWAP.
87 comanche Posted June 18, 2010 Author Posted June 18, 2010 That's my guess. No fluid any where internal slave. junk
87 comanche Posted June 24, 2010 Author Posted June 24, 2010 Lucky me hopefully. Got under the truck today and found fluid on slave cylinder line. Think I will just replace master cylinder and line. Hose was leaking by the pressed fitting.
87 comanche Posted June 24, 2010 Author Posted June 24, 2010 Anybody know where I can find a slave cylinder line? No one has one in stock? Going to try jy but would like to have new one.
