Coil Spring and shock question
I just got a set of stock coil springs for a XJ that I am going to put in the Comanche. Comanche has a 2.5, XJ had a 4.0.
#1 Will putting these coils in only get me to stock height of a 2.5 or will it be higher?
#2 Will the front and back shocks out of the XJ work on the Comanche?
the 4.0L springs **SHOULD** net you an inch or so of lift. even more could be had out of a v8 ZJ (squarish body grand cherokee)
the XJ front shocks will work, rear will not AFAIK.
:agree:
