MjAllTheWay Posted June 3, 2010 Share Posted June 3, 2010 I searched and nothing was found Nothing works is there a fuse or anything i need to look at or a specific ground i can look at to find this problem. Link to comment Share on other sites More sharing options...
abugarcias Posted June 3, 2010 Share Posted June 3, 2010 Did you look at the fuses under the driver's kick panel mounted on the firewall? Look at the turn/backup fuse (20 amp) and the hazard/stop fuse (15 amp). Take them out to inspect because I know on mine they looked ok but when I took them out they were corroded as all get out. Do your instrument cluster lights work? Link to comment Share on other sites More sharing options...
MjAllTheWay Posted June 3, 2010 Author Share Posted June 3, 2010 Yes instrument cluster lights work jest no blinkers or brake lights guna check fuses jest lost them last night on my way to work. Link to comment Share on other sites More sharing options...
MjAllTheWay Posted June 3, 2010 Author Share Posted June 3, 2010 Fixed found a shorted wire on the front blinker Thank you all for your help and advice. Link to comment Share on other sites More sharing options...
Pete M Posted June 3, 2010 Share Posted June 3, 2010 dang it, I was about to suggest that. :doh: Glad to hear it was something simple. :thumbsup: Link to comment Share on other sites More sharing options...
MjAllTheWay Posted June 3, 2010 Author Share Posted June 3, 2010 Well thank you anyway for thinking about it :cheers: Link to comment Share on other sites More sharing options...
