Anybody that does much work on their Jeeps, and other unworthy vehicles, has probably come across this problem. You remove a component and now you have a opened line or fitting, Gas, trans cooler line, A/C line, etc., I have had very good luck using red RTV to plug these holes. Just squeeze a big gob in and let set. Removes very easy, comes out in one big gob and is a lot easier to use than stuffing paper or rags into them. Keeps the dirt out of them lines, and components. Jim
