87_Pioneers Posted May 25, 2010 Share Posted May 25, 2010 I was just wonder if the two and four wheel drive AX-5 are interchangeable I assume they are like any other truck tranny but just checking with you guys. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 25, 2010 Share Posted May 25, 2010 no. output shafts and tailshaft housings are different. otherwise, they are the same...but you need both and some skill to turn one into the other. a nice press is necessary. Link to comment Share on other sites More sharing options...
Geonovast Posted May 26, 2010 Share Posted May 26, 2010 I think he's referring to replacing a 2wd one with e 4wd one for a 4wd swap... yes? Link to comment Share on other sites More sharing options...
87_Pioneers Posted May 26, 2010 Author Share Posted May 26, 2010 No 4x4 truck with bad tranny want to put a two wheel in it. Link to comment Share on other sites More sharing options...
Geonovast Posted May 26, 2010 Share Posted May 26, 2010 What's wrong with the 4x4 trans? Link to comment Share on other sites More sharing options...
87_Pioneers Posted May 26, 2010 Author Share Posted May 26, 2010 makes a noise and only goes in 4th well Link to comment Share on other sites More sharing options...
Geonovast Posted May 26, 2010 Share Posted May 26, 2010 I'm betting your layshaft or a layshaft bearing is screwed. Identical to the 2wd Layshaft, you should be able to swap it in and retain 4wd. I would at least take the 4wd trans apart and see if the 2wd one can save it before popping the 2wd one in. Link to comment Share on other sites More sharing options...
87_Pioneers Posted May 26, 2010 Author Share Posted May 26, 2010 Alright good to know Link to comment Share on other sites More sharing options...
