kyleag89 Posted May 24, 2010 Share Posted May 24, 2010 Will a snap-on solis scanner hook up to an 89 MJ? Quote Link to comment Share on other sites More sharing options...
Automan2164 Posted May 24, 2010 Share Posted May 24, 2010 Nope. The RENIX models don't even have a check engine light in the way you think of one. It doesn't store codes, or anything like that. IIRC, all it is, is an emissions light. Rob L. Quote Link to comment Share on other sites More sharing options...
kyleag89 Posted May 24, 2010 Author Share Posted May 24, 2010 I need to check my trans solenoids and that stuff to see whats wrong. My trans shifts fine manually but when in OD it slips from 1-2 Quote Link to comment Share on other sites More sharing options...
Automan2164 Posted May 24, 2010 Share Posted May 24, 2010 You can check that by pinning out the trans connector, and measuring the ohms of the solenoids. Someone else will have to chime in here about that. Rob L. Quote Link to comment Share on other sites More sharing options...
Wildman Posted May 24, 2010 Share Posted May 24, 2010 You can check that by pinning out the trans connector, and measuring the ohms of the solenoids. Someone else will have to chime in here about that. Rob L. I'll chime in on that :D Here a link for checking the TCU and the solenoids = http://www.transonline.com/transdigest/ ... index.html It's step by step and easy to follow ;) Quote Link to comment Share on other sites More sharing options...
kyleag89 Posted May 24, 2010 Author Share Posted May 24, 2010 Thanks! Quote Link to comment Share on other sites More sharing options...
WBKrazy Posted May 24, 2010 Share Posted May 24, 2010 http://cgi.ebay.com/ebaymotors/AMC-JEEP ... veQ5fTools there's a couple of these on fleabay right now, but it looks like they don't do anything but tell you if the computer's bad or good? :dunno: anyone ever use one of these? Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
