64 Cheyenne Posted May 20, 2010 Posted May 20, 2010 New ones cost nearly a hundred bucks or more @ Rockauto and on Ebay. I want to try a used one first if I can find one. Why TPS? Runaway starts is getting old, try to fix this issue while the 88 is down for gears.
mjeff87 Posted May 20, 2010 Posted May 20, 2010 you can use an auto TPS, you just don't plug in the seperate pigtail that normally goes to the TCU. (I'm running an auto TPS in my MJ now, so I can verify that it works ;) ) Jeff
64 Cheyenne Posted May 20, 2010 Author Posted May 20, 2010 :banana: $$ saved! can't beat that. Thanks much, mjeff87. Chey64
