Hey guys, I forget. I need to adjust my alignment tomorrow - so -
When I twist the tie rod, which way causes the front of the tires to toe-in? Up or down?
Obliged,
WYK
OK, for future reference:
UP toes it in, Down toes it out. At least, it does on my 1986 XLS 4X4.
It only took 1/5 crank down to fix the alignment issues I had. So I wouldn't go cranking hard on it at first. This fixed maybe a 1/8th inch offset
WYK
Gee's I don't know should I use my R hand & go clock-wise or if I use my left-----------------------aahhhh he'll figure it out. :???:
Installing an after market front bumper didn't noticeably drop down the front, but when someone pointed out my bent tie rod (the beefier V8 ZJ one) I decided to check the alignment exepcting to find too much toe-in.
Turned out I had 1/2" toe OUT from the weight of the bumper...
Once you get up past 4.5-5" of lift, it changes a lot with a little difference in ride height.
