okay so i decided to change the oil and gasket on my rear axle. Prolly has never been changed before. I took off the differential cover and there wasn't a gasket to begin with, just a bunch of red rtv gasket goo. I didn't realize there wasn't a gasket so i had already bought one. Should i put the gasket on and just scrape away all the red rtv silicone stuff? They wouldn't make a gasket for it if it wasn't suppose to have one right???? Is it a bad thing to put a gasket on there even tho its never had one?
thanks guys!
-zack
Yep, use the gasket after scraping off and cleaning the mounting surfaces. I usually apply a thin film of hi-temp gasket sealant to the surfaces too. :cheers:
Gasket isn't really necessary. RTV works well, but you need to clean the surfaces very well. Dry them off and apply a thin bead to the cover. then allow this to set for a short time. Then install but do not tighten more than light finger tite. After about a half hour go ahead and torque it down and your ready to fill it!!
You shouldn't get gobs squeezing out around the edges.
CW
