nitroxsteve Posted April 15, 2010 Share Posted April 15, 2010 I just got my mj on the road this week and I'm working the bugs out. The engine runs good and pulls strong but has a rattle in the top end at higher rpms (around 3,000 up). And only while on the gass if you let up and let the engine slow the truck down it stops. It does not sound like a bearing or a piston slapping. It sounds like the valves are loose. Has anyone had a similar problem or have any ideas? I have run seafoam thru the engine and changed the oil to 10w40 penn. As far as I can tell from the shop book you cannot adjust the valves. When I have time I plan on pulling the valve cover to check things out. Thanks Link to comment Share on other sites More sharing options...
89comanchesleeper Posted April 15, 2010 Share Posted April 15, 2010 have you cheked the timen? could be spark knock if its only under loads. Link to comment Share on other sites More sharing options...
nitroxsteve Posted April 15, 2010 Author Share Posted April 15, 2010 have you cheked the timen? could be spark knock if its only under loads. Good thinkin Ill check it tomarrow. It does sound like a spark knock. Link to comment Share on other sites More sharing options...
jimoshel Posted April 15, 2010 Share Posted April 15, 2010 You can't adjust the valves but you can tighten loose hardware. My rattle was caused by rocker arm bridge bolts working loose. Link to comment Share on other sites More sharing options...
