I'm in the process of replacing all the seals and gaskets in my 2.5 and came across a question. The new gasket set comes with both 8 valve seals and also 8 deflectors. The engine currently has deflectors on them, but the kits says to fit the 1986 engines with the actual seals. Which should I use?
Use the seals. A light coat of oil on the stems will help them to slide on. Use a 7/16 deep well socket to push them on with.
